Ignition Coil missing
woytovich
I just picked up a 71 240z in stock configuration... but it's missing the coil. I'm a newbie to Zs... is this a standard item I can get at the dealer or a parts store? Any reason to look at some upgraded coil? This is going to stay a stock, street car...
Thanks,
Mark
Edited by woytovich
Can anyone chime in on what else looks to be missing in the picture... looks like a plug wire, and some plumbing pipe cap and other plugs up top... what's all that about? removed emissions stuff? IT looks like the air hose into the air rail is capped...? Probably means the "smog pump" is disconnected/missing/non-functional?
Boy do I need a Factory Service Manual and a bunch of diagrams for this thing right away!
Mark
Edited by woytovich
Wow, when is the last time that engine has been running? Your smog pump is missing, but not needed for the car to run. Most of the caps are OK, my only concern would be the vacuum and parts that dampen the carb linkage return.
You can get a Petronix electronic ignition set-up for that pretty cheap, and it's easy to install. New plug wires would be good of course as well as new plugs.
Read the theads on engine start-up after long periods of non-operation.
Good luck!
Rich
Edited by motorman7
I sourced an ignition coil from my local (good) auto parts place... I'm not confident it's right. I expected a cylinder shaped coil like this:
and instead they gave me one like in this picture:
The part number on the box is Beck Arnley 178-8025 but the number on the coil is Diamond FTM-063GT
Help!
Mark
Edited by woytovich
  • Who's Online   1 Member, 0 Anonymous, 859 Guests (See full list)
