November 6, 200915 yr Author comment_299561 Interesting. 240Zs had point ignition and 260/280Zs had electronic ignition. Two different coils.What are the issues in upgrading a 240 to electronic ignition? Link to comment https://www.classiczcars.com/forums/topic/33676-ignition-coil-missing/?&page=2#findComment-299561 Share on other sites More sharing options...
November 6, 200915 yr comment_299627 It will work with your car. It doesn't have the proper appearance though. It is not a high output coil so you don't need to worry about burning up points too quickly. An AC Delco p/n U510 is also correct for this application and physically looks like the original. Link to comment https://www.classiczcars.com/forums/topic/33676-ignition-coil-missing/?&page=2#findComment-299627 Share on other sites More sharing options...
November 6, 200915 yr comment_299646 Another option is the dizzy from a 280ZX, preferably with a e12-80 ignition module. If you go with a ZX dizzy you will want to use the ZX coil, too. Do a search and you should be able to find the information you need to do this swap. Link to comment https://www.classiczcars.com/forums/topic/33676-ignition-coil-missing/?&page=2#findComment-299646 Share on other sites More sharing options...
November 6, 200915 yr comment_299647 A quick trip to google world, gave me this page http://www.mdparts.com/beck-arnley/beck-arnley-ignition-coil-178-8025.php doesen't look close to the one you put a photo up of, but have the same shape as the original, for the specs, dunno.Chris Link to comment https://www.classiczcars.com/forums/topic/33676-ignition-coil-missing/?&page=2#findComment-299647 Share on other sites More sharing options...
November 7, 200915 yr comment_299690 Interesting. 240Zs had point ignition and 260/280Zs had electronic ignition. Two different coils.Can't speak for the US but Euro 260's had point ignition and as this one has a ballast resistor I suspect it is also point ignition. Link to comment https://www.classiczcars.com/forums/topic/33676-ignition-coil-missing/?&page=2#findComment-299690 Share on other sites More sharing options...
