  Orangys280Z said:
Woah! Where did you find that? That's pretty cool!
Not mine. It was found in a LV JY .. on the valve cover of a 260Z??
I'm just trying to see if anyone knows the history behind it .. if there is a history.
https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298964
Is it about 7/8" in diameter, with a small spot weld or remnant of a pin on the back? If so, it's a hat / lapel / jacket enamel pin.
I have two, not in that style, that could be considered "cousins" except that the "Z" is proper and not this different font.
FWIW
E
https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298991
