Posted October 30, 200915 yr comment_298960 Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/ Share on other sites More sharing options...
October 30, 200915 yr comment_298961 Woah! Where did you find that? That's pretty cool! Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298961 Share on other sites More sharing options...
October 30, 200915 yr Author comment_298964 Woah! Where did you find that? That's pretty cool!Not mine. It was found in a LV JY .. on the valve cover of a 260Z??I'm just trying to see if anyone knows the history behind it .. if there is a history. Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298964 Share on other sites More sharing options...
October 30, 200915 yr comment_298968 How big is it? Looks like something that would be on the top of an after market gear shift lever. Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298968 Share on other sites More sharing options...
October 30, 200915 yr comment_298978 Enamel Pin Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298978 Share on other sites More sharing options...
October 30, 200915 yr comment_298991 Is it about 7/8" in diameter, with a small spot weld or remnant of a pin on the back? If so, it's a hat / lapel / jacket enamel pin.I have two, not in that style, that could be considered "cousins" except that the "Z" is proper and not this different font.FWIWE Link to comment https://www.classiczcars.com/forums/topic/33694-id-this/#findComment-298991 Share on other sites More sharing options...
