Posted November 6, 200915 yr comment_299570 The Water Temperature Switch on my '75 280Z checks no continuity at any state, hot or cold and needs replaced. The only one I find is at the Z store for a 74 260Z. Will it work?? Link to comment https://www.classiczcars.com/forums/topic/33754-water-temperature-switch/ Share on other sites More sharing options...
November 6, 200915 yr comment_299617 Check this thread:http://www.classiczcars.com/forums/showthread.php?t=35873Post #1 and #21 should answer your question. Link to comment https://www.classiczcars.com/forums/topic/33754-water-temperature-switch/#findComment-299617 Share on other sites More sharing options...
November 6, 200915 yr Author comment_299621 Yellow Fever,90 degrees is close enough for me too! (ref Post #21)Thanks Link to comment https://www.classiczcars.com/forums/topic/33754-water-temperature-switch/#findComment-299621 Share on other sites More sharing options...
