In my L-24 I am running a '79zx dist, and am going to replace the cap and rotor. I just wondered if any one had an openion on the brands of parts. I use ngk BP6RS plugs which I will stay with but what about the cap and rotor , DAIICHI OR BOSCH , or one that is a F2010-27437. I am not aquainted with any of these and wondered if they are with aluminum or brass contacts . The cost is not an issue it quality that I want . Is the F2010 Nissan ?? I have a new set of ignition 8mm wires . Thanks in advance .
I would recommend that in all instances with electrical components to do with a Z or any other Datsun/nissan go with the manufacturer of the oem component fitted, for bosch distributor stick with that brand cap and rotor and all other minor components. the reasoning for this is you get suttle diffrences in the configuration of the components and they may not run well to gether if at all, especially rotor button to distibutor cap. Mitsubishi electric also supply a distributor in this age range for the L series engine and the same rule would apply. My brands of choice is hitachi for all electrical component and yes NGK BPR5ES-11 sparkplugs for my L28E daily runner.
Hope this helps
Steve
