I think a broken bottom mount would work fine if the bumper on top stopped the upward movement of the diff. The only thing the stock diff mount would do is keep the diff from hitting the crossmember, and unless the rubber comes entirely out I don't think that's likely to be a problem.
I totally hear ya. I'm just trying to suggest people use unbroken parts. The bump stop will stop the diff from moving up, when used on the R/T mount and the broken or even new one, will keep the diff from smacking the crossmember.
It is possible, but you'll have to......
Mount the R/T mount to the Z without the GM mount attached.
Loosely mount the GM poly mount to the top of the diff and the Stock mount to the bottom.
Mount the Poly to the R/T mount and tighten it all up, including the 2 large bolts so everything is tight.
Then mount the crossmember to the stock mount with the nut and washer.
Then you'll have to use a floorjack to compress the crossmember up to the car to bolt it in place with the 4 bolts.
This will literally compress both mounts and ain't Nothing Moving after that.
I'll use this post (#65) to post updated info on orders (requests, payments sent and payments received)
I want 1.......... (1) - Order and Payment Received
vercingetorix.... (1) - Order and Payment Received
Motorman7...... (1) - Order and Payment Received
Diseazd........... (1) - Order and Payment Received
SteveE........... (1) - Order and Payment Received
260ZCaliCar......(1) - Order and Payment Received
Duffman...........(1) - Order and Payment Received
RT Hunter.........(1) - Order and Payment Received
GreenZZZ.........(1) - Order and Payment Received
Zup.................(2) - Order and Payment Received
SSuspect.........(1) - Order and Payment Received
MEZZZ.............(1) - Order and Payment Received
pbarcher..........(1) - Order and Payment Received
Marty Rogan.....(1) - Order and Payment Received
Pop's Z............(1) - Order and Payment Received
Oiluj................(1) - Order and Payment Received
Gully Foyle........(1) - Order and Payment Received
=Enigma= ........(1) - Order and Payment Received
Zedyone_kenobi (1) - Order and Payment Received
Z_Tyler_Z.........(1) - Order and Payment Received
ZKars...............(1) - Order and Payment Received
conedodger......(1) - Order and Payment Received
bajcsi..............(1) - Order and Payment Received
ol'red70...........(1) - Order and Payment Received
ARNE...............(1) - MS
Nigel1943.........(1) - MS
ConchZ........... (1) - MS
Phred..............(1) - MS
70 Cam Guy......(1) - MS
Tarmac............(1) - MS
nahurry............(1) - Not Yet
JohnnyRock.......(1) - MS
I know I say it almost every time, but Thanks guys.
Dave
Edited by Zs-ondabrain
Hi Dave,
Count me in! I will get the MO in the next couple of days and send it over. I'll send you the info. I will install everything in the next few weeks when I swap the 4:11 R180 setup into the car.
For everybody else as an FYI... I also had Dave rebuild my turn signal and headlight combo switches and I installed his HLH and PLH harnesses in my 2/71 240. This car is not yet on the road, but I am VERY close. The quality of Dave's work as well as his customer service and ease of installation is OUTSTANDING!
I will put together a full post of my build (over the last year) in a few weeks. I can't wait to get this car rolling! I will get my door seals this week (needed to complete the interior install). I will bolt my seats in next weekend and take it around the block for the first time since I bought it... WooHoo!!!
Thanks for putting this together Dave!!!
Tim
Edited by SSuspect
