What is this ?
kjphilippona
I need help identifying this box, as you can see the cover is all but gone and it sits nexto the fusible links directly under the poorly engineered hood vent on the passengers side that does not have a plate to stop water from pouring on to it. Not sure if i have to replace the whole box or if i can get a new cover :disappoin
Edited by kjphilippona
I think that's an A/C relay. I might even have one laying around. I'll check and get back to ya.
**OK** found it. But it looks like you'll have to unsolder the wires on your relay to install the rubber boot.
I'll give you the whole thing for $6.00 Shipping.
PM me if you're interested.
Dave
Edited by Zs-ondabrain
  • 3 weeks later...
place the 2 relays next to each other, you'll see that the soldered terminals should line up. unsolder then all, slide the 280Z wires thru the new boot from the 260Z relay then solder the wires back onto the 280Z relay.
That way you're still using a Known good relay with a better looking boot and the correct connector.
  • Who's Online   1 Member, 0 Anonymous, 745 Guests (See full list)
