tlorber Posted November 16, 2009 Share #1 Posted November 16, 2009 Well, after searching for a while I finally picked up a '73 240. The body is about as unmolsted as I have seen-the sound of metal everywhere you tap, and the interior is in great shape. Even the friggin clock works. It has a N42 block w/N47 head but the original 4 speed. I have short term plans to dial it in, and then long term plans for mild building. So here are my questions:1) Tach is off-it shows much higher than actual rpms. Can I remove the tach from the rear or does the dash have to come off?2) Any trick to bleeding the brakes, or can I just drain the lines?3) (Longer term) Can I just put a P79 on the existing block with flat top pistons, or is the the F54 block significantly different?Thanks for any input. Link to comment Share on other sites More sharing options...
Walter Moore Posted November 17, 2009 Share #2 Posted November 17, 2009 Welcome!I will answer the questions that I can:1. The tach reading high is pretty typical, particularly if the ignition has been upgraded.2. Bleeding the brakes is just like any other older car.3. I have no idea, but I am sure someone else around here does. Link to comment Share on other sites More sharing options...
FastWoman Posted November 17, 2009 Share #3 Posted November 17, 2009 1) It comes out through the front of the dash. One screw in the top of the bezel, and one underneath and maybe 6 or 7 inches farther towards the front of the car.4) You definitely should invest in a Nissan factory service manual. You can find one on Amazon or Ebay -- both used, of course. Link to comment Share on other sites More sharing options...
tlorber Posted November 17, 2009 Author Share #4 Posted November 17, 2009 Thanks. Is the Nissan manual better than a Haynes book?Also, after closer inspection, the block IS a F54, with a N47 head. Based upon what I've read, I'm not sure how that works without super high compression unless the pistons have been swapped for dished. I know the compression is not that high based upon the way it drove home.The car has a stock exhaust mani and a dinky (appx 1.5") pipe to the rear.Glad to have a Z finally. Link to comment Share on other sites More sharing options...
