Posted November 17, 200915 yr comment_300559 Some Hitachi SU's and Intakes have coolant ports.I notice that the latter ones do not.Is there any advantage to it or not.Also , can a SU carb with the coolant ports be put on a non coolant intake and visa versa.thanksAl Link to comment https://www.classiczcars.com/forums/topic/33858-su-intake-coolant-ports/ Share on other sites More sharing options...
November 17, 200915 yr comment_300562 Funny, there are two other threads talking about this right now. General consensus is if you live in Alaska or Montana, you'll want them hooked up, otherwise take them off. Problem is that if you live in the snow belt, you probably have more rust then car... Link to comment https://www.classiczcars.com/forums/topic/33858-su-intake-coolant-ports/#findComment-300562 Share on other sites More sharing options...
November 17, 200915 yr Author comment_300568 I can't find the other threads. Link to comment https://www.classiczcars.com/forums/topic/33858-su-intake-coolant-ports/#findComment-300568 Share on other sites More sharing options...
November 17, 200915 yr comment_300574 This is what I was reading (and writing)http://www.classiczcars.com/forums/showthread.php?threadid=36524http://www.classiczcars.com/forums/showthread.php?threadid=35909&page=3 Link to comment https://www.classiczcars.com/forums/topic/33858-su-intake-coolant-ports/#findComment-300574 Share on other sites More sharing options...
November 17, 200915 yr comment_300616 The early 4 screws have no provision for water into the carb base. Three screws do have the holes through the insulators into the carb base. The flat top manifold mounting flange profile matches up with the 3 screw flange profile i.e, non symmetrical while the 4 screw flange is symmetrical. Hope that helps. Link to comment https://www.classiczcars.com/forums/topic/33858-su-intake-coolant-ports/#findComment-300616 Share on other sites More sharing options...
