Posted November 17, 200915 yr comment_300566 I can't seem to find out what that thing is.. It doesn't look like the front mounts I have seen. I am trying to swap a R200 3.9 into my 72 240z and I was told this is what I would need, however, where does this piece go? Thanks a lot, Elliot Link to comment https://www.classiczcars.com/forums/topic/33859-what-is-this-r200-swap240z/ Share on other sites More sharing options...
November 17, 200915 yr comment_300570 That's a crossmember for a transmission. 260Z and 280Z I believe. You can see it on my trans, under the caliper in the 2nd picture. Dave Edited November 17, 200915 yr by Zs-ondabrain Link to comment https://www.classiczcars.com/forums/topic/33859-what-is-this-r200-swap240z/#findComment-300570 Share on other sites More sharing options...
November 17, 200915 yr Author comment_300571 Thanks for the fast response. Good to know that its completely useless on my car . Anyway.. Are the R180 and R200 front mount the same ( other then the exhaust cutout)? Elliot Link to comment https://www.classiczcars.com/forums/topic/33859-what-is-this-r200-swap240z/#findComment-300571 Share on other sites More sharing options...
November 17, 200915 yr comment_300591 Cutlass372 said: I can't seem to find out what that thing is.. That mount was first used for the 1972 model. Link to comment https://www.classiczcars.com/forums/topic/33859-what-is-this-r200-swap240z/#findComment-300591 Share on other sites More sharing options...
