Posted November 22, 200915 yr comment_301044 What is the secrect to removing the connecting rod that goes from the balance tube to the linkage on a 72 Z. I getting ready to remove the head and can't seem to get this off. I don't want to break it. looks like plastic ends. Link to comment https://www.classiczcars.com/forums/topic/33907-balance-tube-to-linking-rod/ Share on other sites More sharing options...
November 22, 200915 yr comment_301047 It does just pop off. To avoid breaking it spray some Armoral on it for lube. You could try warming it up with hot water on a rag. Push with your thumbs don't pry on it with any tools. Link to comment https://www.classiczcars.com/forums/topic/33907-balance-tube-to-linking-rod/#findComment-301047 Share on other sites More sharing options...
November 23, 200915 yr comment_301077 ArmorAll for lube? That's a new one. Edited November 23, 200915 yr by =Enigma= Link to comment https://www.classiczcars.com/forums/topic/33907-balance-tube-to-linking-rod/#findComment-301077 Share on other sites More sharing options...
November 23, 200915 yr comment_301088 I take a pair of needle nose plyers and wedge under it, gently rocking back and forth till it pops off.Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/33907-balance-tube-to-linking-rod/#findComment-301088 Share on other sites More sharing options...
November 23, 200915 yr Author comment_301116 Thanks guys I will do it tonight. Did not want to break it. Link to comment https://www.classiczcars.com/forums/topic/33907-balance-tube-to-linking-rod/#findComment-301116 Share on other sites More sharing options...
