Silver solder should work for your needs. I have made model ship propellers with it, so it should be able to stick some tubes together. Clean well, and use flux. You can use a big soldering iron, or flame.
I usually get mine at the hobby supply store, but otherwise it's used in jewelry-making. Stay Brite 8 is the name (Tin-Silver alloy.) You might even try eBay for 15% silver solder.
Edited by TomoHawk
