I don't have my CD handy (at work), but the entire CD is divided up into pdf files. The front end that you open in internet explorer basically just links to these PDFs. Try browsing around your CD and find the "master" pdf that links to all the other ones. You don't need IE at all to view the materials.
I think Inf is correct. You may need to upgrade or install some of the IE add-ons like the FlashPlayer to get everything to work off the CD. Otherwise, you can copy all the pdf files (Mine had S30_1a.pdf through S30_8b.pdf and one named INDEX.TXT) to your hard drive for faster access. The Index file tells you which pdf file covers what.
