Posted December 10, 200915 yr comment_302853 Any tips on how to open the gaz door of a series 1 without having the keys....The key I have for the ignition won't match the lock on the gaz door.Thanks for your help!Joce Link to comment https://www.classiczcars.com/forums/topic/34093-need-to-open-the-gaz-door-with-no-key-help/ Share on other sites More sharing options...
December 10, 200915 yr comment_302855 The key lock was not standard (just used a non-locking twist knob), so it's not at all surprising that the door key doesn't fit. I'm afraid that if the correct key is not available, you may be forced to have a locksmith look at it, or drill out the lock yourself. Link to comment https://www.classiczcars.com/forums/topic/34093-need-to-open-the-gaz-door-with-no-key-help/#findComment-302855 Share on other sites More sharing options...
December 10, 200915 yr comment_302856 take it to a locksmith, have him pick it then make a key. Link to comment https://www.classiczcars.com/forums/topic/34093-need-to-open-the-gaz-door-with-no-key-help/#findComment-302856 Share on other sites More sharing options...
December 10, 200915 yr comment_302863 jcote75 said: Any tips on how to open the gaz door of a series 1 without having the keys....The key I have for the ignition won't match the lock on the gaz door.Thanks for your help!JoceA good locksmith can make a key fo it just by using a key blank and looking for the marks the pins leave on it and filing the marks. Its a job that you can do yourself with the correct blank and a file. Link to comment https://www.classiczcars.com/forums/topic/34093-need-to-open-the-gaz-door-with-no-key-help/#findComment-302863 Share on other sites More sharing options...
December 12, 200915 yr Author comment_302989 Got it.I've been able to twist enough with a screw driver so that the pin was clear. Good thing this is to be able to paint the car and was not done on a fresh painted car! Link to comment https://www.classiczcars.com/forums/topic/34093-need-to-open-the-gaz-door-with-no-key-help/#findComment-302989 Share on other sites More sharing options...
