few EZ-wiring questions (72' 240)
Kris.is.awesome
When you mention "tapping into the ignition wires", I presume you mean wiring it as the schematic you posted specifies, if so; yes it would work.
The resistor is bypassed in the START mode of the ignition switch, i.e the points/dizzy get full voltage sent from the ignition switch first through the tach and then to the points.
In the RUN mode, the voltage is first sent through the resistor, then to the tach and then to the points.
E
Okay, cranked her over this morning. Battery in the car is toast so I've been 'jumping' it from my running car. After just a little bit of cranking it hiccuped. It's just keep barely firing- but I found after measuring the voltage going into the coil was dead when in the 'run' position. Apparently my harness does not keep the coil hot while in the 'run' position. For testing's sake- I should be safe making a jumper from the batt+ to the coil?
Also- which wire on the alt would be the excitor?
  • 10 years later...
