Air Dam Advice
Victor Laury
Most of the air dams do connect using the existing bolt holes.. I will post a closeup of the mounting for my air dam tonight... I don't have a picture showing any of the details yet, but I will take one. I used cariage bolts to connect mine. After the heads are painted they look pretty good. The most important part, (for me) is to build a floor right behind the dam to bridge the gap between the frame and the back of the air dam.. If you don't build it the air dam is just trim, not a functional air dam. I build these out of aluminum.
I had a fiberglass air dam once. When ever I would accidently run into a side walk or other unmovable object my air dam would take the beating. It slowly got trashed, small cracks then bigger ones then finally it was just falling apart. I went to the urathane air dam and it is more flexable. It is more forgiving that the fiberglass ones (go urathane). But like smg1404 said you have to support the dam underneath. High speed will make the dam flex and fold under. Motorsports has a good variety try them. I believe most of there dams will bolt on.
  • Who's Online   2 Members, 0 Anonymous, 989 Guests (See full list)
