Posted December 24, 200915 yr comment_304082 I've got to move my z from it's present location and own neither truck nor trailer, and can't rent one either. so I'm hoping to be able to drive the car to it's new home.I appreciate anything anybody can help with. She needs:~Brakes bled - I did them as I normally would, front and back. Still have no brakes. No stopping power aside from the E-brake.~Clutch - needs bleeding. Bled them as I knew how. Nothing still.~Fuel - OK, so here's a big let down. Its not pulling fuel from the tank. So I'm not sure if it's the fuel pump or injectors. Everything else appears to be in good or OK condition. Any ideas how to assess these issues quickly? Thanks. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/ Share on other sites More sharing options...
December 24, 200915 yr comment_304088 Not quickly. Suggest you hire a roll-back tow truck..... Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304088 Share on other sites More sharing options...
December 24, 200915 yr comment_304092 I agree, probably no quick fix. The clutch and brakes are likely a matter of getting the system blead. There could be issues beyond that as well, wheel cylinders, slave, masters, etc. As for fuel, can you hear the pump run when you initially turn on the key? It should chatter for just a few seconds. How long has the car been setting? Tank could be gummed up too. Fuel filter could be plugged. Could be......How far do you have to move the car? Depending on the urgency, it sounds like it is going on a car tailer. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304092 Share on other sites More sharing options...
December 24, 200915 yr comment_304106 Do you have AAA? How about a friend with AAA+?Otherwise... a tow rope, a dark night and a friend with a car.FWIWE Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304106 Share on other sites More sharing options...
December 24, 200915 yr Author comment_304127 Blasted gulldurnit! Well, No to the fuel pump noise. At least I don't think I heard it. I'll check on Friday. I have to go from one town to the other. It's not all that far, about 15 or so miles. I might end up doing the friend with a car bit. I don't have a trailer, and don't know anybody with one who'd let me use it. My uncles does have a truck, so that might help. Unfortunatley, my mom used the last of my AAA towing miles that I had for free. I had around a 100, but she used them (just found that out today) through out the year.Oh well, thanks for the help. Just have to keep working on it. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304127 Share on other sites More sharing options...
December 25, 200915 yr comment_304135 If you don't get the rattle from the fuel pump, you may not be getting power to it. I'd probably start there, check the fusable links with a test light and wiggle them to insure contact. How long has it been since this car was driven last? Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304135 Share on other sites More sharing options...
December 25, 200915 yr comment_304141 Don't know that I'd try a tow rope without working brakes if you also can't downshift to use engine braking since the clutch is inoperable. That could be a disaster. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304141 Share on other sites More sharing options...
December 25, 200915 yr comment_304147 Try stringing a wire directly from the battery to the fuel pump, at least long enough to get you home. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304147 Share on other sites More sharing options...
December 25, 200915 yr comment_304148 I definitely recommend a flatbed. I did this when I moved from one town to the next. The move was about 12 mi and $120 but well worth it for the peace of mind. I had to put things together in a hurry to get a rolling chassis and didn't want to test the brakes or get stuck halfway there. The tow guy was great and dropped it straight into the garage safe and sound. Definitely one of the best investments I've made in the car so far. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304148 Share on other sites More sharing options...
December 25, 200915 yr comment_304163 Recently bleeding my brakes, I discovered that the master on my Z (1975) has bleed valves on the MC, and if the reservoir has run dry, no amount of bleeding the wheels will give you pressure back if you don't first bleed the master.I haven't looked to see if it is the same for the clutch.Geof Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304163 Share on other sites More sharing options...
December 25, 200915 yr comment_304173 I'd call and get a flatbed or rent a truck and trailer from U-haul, Budget. . . they have stuff for that ya it might cost you money but rushing around causes problems. Get it some where you can work out the problems then fix it I don't recommend driving a car with bad brakes or brakes that were fixed in a rush!! You can cause a lot of damage if you don't think this threw. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304173 Share on other sites More sharing options...
December 25, 200915 yr Author comment_304180 10-4. I hear ya guys. I merely meant an easy fix, but that's OK. Mostly I just have to get it moved before sweep day. Stupid street sweepers....give me a freaking ticket if it's on the street...Ill keep working on it. I think I might be able to push it into the driveway before then. Hopefully Ill be able to anyway. Link to comment https://www.classiczcars.com/forums/topic/34216-need-some-help/#findComment-304180 Share on other sites More sharing options...
