Posted December 26, 200915 yr comment_304203 Transmission or differential problem on a 1972 240z with 160000 miles on it, car has sat for 8 years, bought it 4 months ago, got it running, doing about 40 miles per hour and grinding noise starting coming from the rear passenger side differential area. Noise only when I try to excellerate but all the gears seem to work and shift ok. Before I start to get into it, just wanted to get an idea what to look for or what the problem could be. Have not added or changed any fluids in trans or differential. I am wanting to fix as much as I can myself and keep original. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/ Share on other sites More sharing options...
December 26, 200915 yr comment_304218 Bearings. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-304218 Share on other sites More sharing options...
January 8, 201015 yr comment_305520 I was thinking about trying to replace my bearings in my rear end, but after reviewing the FSM, I do not think its a DIY type of job. Many special tools needed both off the shelf and Datsun factory special tools. Not sure as I am pretty sure I have a rear bearing on my passenger side of the diff that needs some removing and replacing. I think I may just try to replace the whole thing. I just have to find one that is in better shape than mine. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305520 Share on other sites More sharing options...
January 8, 201015 yr comment_305529 I'd suspect wheel bearings before diff bearings. If it is diff bearings, the diffs don't have serial numbers, so any 3.36:1 R180 out of a 240Z is going to be just like any other. Wheel bearings generally react to side to side thrust. So if you swerve back and forth you should hear the noise stop or change on a wheel bearing. The diff is in the center, so I doubt you'd be able to tell passenger's side carrier bearing from a driver's side carrier bearing. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305529 Share on other sites More sharing options...
January 8, 201015 yr comment_305549 Could it be simply one of the u-joints on the halfshafts? Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305549 Share on other sites More sharing options...
January 9, 201015 yr comment_305587 Could it be simply one of the u-joints on the halfshafts?u-joint symptoms are usually a clunk sound, grinding noise seems to be brakes or bearings, my vote is bearings. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305587 Share on other sites More sharing options...
January 9, 201015 yr comment_305594 I'd suspect wheel bearings before diff bearings. If it is diff bearings, the diffs don't have serial numbers, so any 3.36:1 R180 out of a 240Z is going to be just like any other. Wheel bearings generally react to side to side thrust. So if you swerve back and forth you should hear the noise stop or change on a wheel bearing. The diff is in the center, so I doubt you'd be able to tell passenger's side carrier bearing from a driver's side carrier bearing. I agree completely. I say that because I have been thru the wheel bearing thing with my 1972, as well as several other Z Car related issues's. And sitting for so long did not help anything on your car as well. And I say this because mine sat in a garage for 7 1/2 years. One of the first things I did was get rid of the 3.36 R180 and put in a 3.54 R200.What a difference. Got the R200 for $150.00. Now 6 years later and many hours of tinkering and fixing it runs perfectly. Drive him just about every day and we both love it. Now all I have to do is get a little extra cash together so he can get painted. Edited January 9, 201015 yr by barth4567 Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305594 Share on other sites More sharing options...
January 9, 201015 yr comment_305614 My grinding noise in the back was from bad rear brakes when I got my car after it had less than 5000 miles between 1983 and 2008. After a rear brake rebuild and new master it was fine. Going to have to replace the u-joints some day, its on the list. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305614 Share on other sites More sharing options...
January 9, 201015 yr comment_305617 Start you diagnosis and fix from the simple and cheap end of the scale. Remove the wheels, tires, and brake drums and start inspecting there - as suggested above. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305617 Share on other sites More sharing options...
January 9, 201015 yr comment_305655 Man everybody is right it could be anything. Some times when some one works on the brakes they bent the back plate so the drumm drags around it thus making a grainding sound. also the bearings can be on the differential or the ones on the hub. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-305655 Share on other sites More sharing options...
February 7, 201015 yr Author comment_308891 Hey everyone, I drained the differential fluid and refilled. That was the problem, very little drained out and now the noise is gone. All I can say is thanks to everyone, I feel good to be a member of the Classic Zcar club. Link to comment https://www.classiczcars.com/forums/topic/34226-differential-problem/#findComment-308891 Share on other sites More sharing options...
