January 5, 201015 yr comment_305113 Update/backdate. Very early 240Z arms are shorter by a little bit.Good to know. Thanks! Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305113 Share on other sites More sharing options...
January 5, 201015 yr comment_305117 The drawback is the ball joint stud taper. You need to have the early arms machined to match the taper of the later ball joints. That's a gray area and might lead to a protest, if anyone is smart enough to figure it out. A defense might be that the original ball joints are NLA and this is part of a normal maintenance/repair process. Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305117 Share on other sites More sharing options...
January 5, 201015 yr comment_305119 Jon,Which stock cam is a "C" cam?BTW, did you send in your support to the SEB regarding this proposal? Edited January 5, 201015 yr by Curtis240Z Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305119 Share on other sites More sharing options...
January 5, 201015 yr comment_305120 Vic's "full interior" was an interesting interpretation. It clearly was determined to be legal as it would certainly have been protested at Nationals when he won with it. It was, as I recall lightweight carpet screwed to the door panels and the same on the floor. It wasn't so much THE full interior as it was A full interior.Very fast car and driver... Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305120 Share on other sites More sharing options...
January 5, 201015 yr comment_305121 The drawback is the ball joint stud taper. You need to have the early arms machined to match the taper of the later ball joints. That's a gray area and might lead to a protest, if anyone is smart enough to figure it out. A defense might be that the original ball joints are NLA and this is part of a normal maintenance/repair process.Anyone protesting that would have to know Z cars and your car like a brother. Not likely to be noticed. Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305121 Share on other sites More sharing options...
January 5, 201015 yr comment_305174 The "C" is the cam from the 260Z if I'm correct. Again, this swap is a gray area thing - actually, its plain illegal given the update/backdate requires the engine to be swapped as a complete unit. But, based on how SCCA tests cams, the specs will be within their range of error when they measure duration.Its not that critical of a change because the power difference is very small.I sent an e-mail in requesting the change, although I'm not going to build a car for the class. I was much more interested in the short lived proposal to put the 280ZXT on the same line in BSP as the 240Z. Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305174 Share on other sites More sharing options...
January 5, 201015 yr comment_305175 If the proposal goes through my car is ready. I just got to get the travel logistics organized and that is a very expensive task considering my location, but definitely worth the shot. Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305175 Share on other sites More sharing options...
January 7, 201015 yr comment_305447 If it does go through, it will not become effective until 2011, so you should have plenty of time to get the travel plans worked out... Tom Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305447 Share on other sites More sharing options...
January 8, 201015 yr comment_305484 What about a ZX?Would it be too heavy?Stiffer chassis than the S30? I have no idea but if the ZX is the bastard child then it would be fun to get one competitive, put some noses out of joint. Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305484 Share on other sites More sharing options...
January 8, 201015 yr comment_305487 Richard you are WAY too happy on the ZX. Curtis, you really want to ship your car 5 or 6000 miles for 3 minutes of seat time and a trophy IF you place? Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305487 Share on other sites More sharing options...
January 8, 201015 yr comment_305513 Making a competitive BSP ZXT will be a definite longshot... It's been in that class for decades and I haven't heard of anyone doing it yet. The Evo's are dominating that class and show no signs of letting go.Tom Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305513 Share on other sites More sharing options...
January 9, 201015 yr comment_305589 Curtis, you really want to ship your car 5 or 6000 miles for 3 minutes of seat time and a trophy IF you place?If the proposal goes through I'll take my Z to Nationals for sure! Link to comment https://www.classiczcars.com/forums/topic/34269-how-would-you-build-a-dsp-auto-x-z/?&page=2#findComment-305589 Share on other sites More sharing options...
