It is a 27mm, but if the front pulley is like the stock unit on an L24 you will need a thin wall (non-impact) 6 point socket. An impact socket will not fit in the opening, and a 12 point doesn't have the necessary grip.
It is really difficult to get a 6 point metric stock in the U.S. that will do the job, however a 1-1/6" standard 6 point socket is easy to get, and works just fine.
(1 1/6" = 26.9875mm in theory so 27mm in practice.)
I'm confused Walter. There is tons of room around the bolt on all of the L24-L28s I've owned. Maybe they early L24s are different, but from '72 on, they have at least an inch all the way around the head.
As far as the socket, I use a 27mm Craftsman. They are a regularly stocked item.
Same for my Series II '71.
