Posted January 3, 201015 yr comment_304916 As part of my switch to a Megajolt ignition i build a small electronic circuit to convert the "four wire" current driven Datsun tacho in my '72 240Z into an electronic tacho, which can directly be connected to the tacho output of the Megajolt, MSD, Bosch, Crane or other electronic ignition. Quite surprisingly, the 38 year old tacho was very precise after a calibration, with the highest display error below 3%. You'll find a complete description including the wiring diagram, pcb files and images here: http://www.dinoplex.org/tachoconversion/ Best, Adrian Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/ Share on other sites More sharing options...
January 3, 201015 yr comment_304928 Awesome job. Thanks for sharing. Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-304928 Share on other sites More sharing options...
December 21, 201212 yr Author comment_409775 I've set up a new project which contains a full replacement of the existing board. It is as simple to build as my previous conversion but is based on standard components and does not require an attiny programmer or programming software anymore. The old project is now deprecated, the new one can be found at the same link: http://www.dinoplex.org/tachoconversion/ Enjoy, Adrian Edited December 21, 201212 yr by alhbln added picture of converted 240Z tach Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-409775 Share on other sites More sharing options...
December 21, 201212 yr comment_409779 Thank you. I have been searching online about how to build a tachometer. I even have an old one to play with. By the way, would you mind if I host your write-up on my blog, too? Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-409779 Share on other sites More sharing options...
December 21, 201212 yr Author comment_409784 By the way, would you mind if I host your write-up on my blog, too? Sure, but please keep the reference to my website Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-409784 Share on other sites More sharing options...
December 21, 201212 yr comment_409786 Of course, I would be more than happy to do so. Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-409786 Share on other sites More sharing options...
December 21, 201212 yr comment_409803 Nice stuff! Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-409803 Share on other sites More sharing options...
March 25, 201411 yr comment_444094 Adrian, I would very much like to do this project, but I might need some help .I have a buddy that will make the circuit board for me, but I will need guidance installing it. I would document everything with pics and add to this thread with your permission. I already noticed that my 71 tach looks slightly different, but I might not know what I am looking at Link to comment https://www.classiczcars.com/forums/topic/34295-converting-a-four-wire-tacho-current-driven-to-an-electronic-tacho/#findComment-444094 Share on other sites More sharing options...
