Jon, Took a couple extra for ya. They're at the bottom.
So I got back out there today and ground down the spot welds, cleaned all the rust and sprayed the exposed metal with weldable primer. Then I fitted the skin to the shell and aligned the front window area first, clamped it down then moved along the sides, which I might add, dropped right inplace. I only had to shave 1/8" off the rear of the panel and they corners dropped in place.
More to come after I grind the welds, smooth it out and primer it.
Dave
Edited by Zs-ondabrain
Ya, so far........
Got a little ways to go, finish the welds and gringing, fill the cracks and prime it. I'm almost thinking I should have put the headliner on while the roof was off the car. But then again, I'd like to do the Dynamat on the metal first.
Thanks again for the inspiration. I almost hurt myself, patting my own back yesterday. LOL
Dave
Dave,
The re-skin is looking good. It warms my heart to know the roof has a new rust free home on your 260 project. I know it bothers some when I part out a car, but nearly every part lives on with another Z. If we didn't have spare organs, how would we keep our cars alive? You're doing a beautiful job. I'm glad I could help.
Ken
P.S to "kenz240z" I have a '71 Series II with a license plate that reads "KENZ240". Too funny. My wife also bought me a t-shirt for Christmas with "Still Plays With Cars" on it. Cracked me up when I saw your signature.
Very impressive Dave. I'm curious if you considered using metal bonding adhesive rather than welding during your planning stages, and if so why you chose to weld the top back on? I saw this method used with an early model Mustang last night on a recorded episode of Musclecar and was curious about the pros and cons.
Hi, Ken. Great minds think alike! The spare parts are getting harder to find. The Z cars are not showing up in the salvage yards here in northern Colorado like they used to. In fact, one yard crushed out a half dozen or so cars last year :>( I'm starting to consider stockpiling parts in the rafters of my shop. I'd consider buying another Z car or two, but just don't have the space...gotta finish up a few of the others works in progress: 64 Impala, 65 Buick convertible & 73 V8 Z.
Everything on this project is "On a budget" So when I considered Bonding agent VS Good Ol' fashioned welding, the choice was easy. Welder was in the shop, wallet was empty, no real dispute there.
I also looked at "Metal Fill"?? or "All Metal"?? an aluminum based filler (bondo) for filling the cracks and such but it was $30 a quart or $100 a gallon, so that was a No Go. And the Dura Glass was also expensive. So I'm gonna mix up some polyester resin with a bunch of cut up fiberglass in the mix, to fill the cracks, Versus doing Lead Work.
I'm also gonna do the same thing for the Shaved door handles on the doors. I cut out the door handle area's and welded in some formed steel plates, and will fill the low spots with the resin/glass mix. I WON'T use bondo on the doors and roof corners. Too much risk of cracking, shrinking etc.
KEN, Thanks again for the roof. I myself, am a registered Donor so I totally hear ya. I've bared witness to your Doctoral skills of getting the right parts to the people in need. Too bad Real Doctors don't work that way.
I'm gonna do some more work on the roof and hatch today so I should be able to report back tonight.
Dave
Hi Zs ondabrain I am not sure if this is the right place for this question but here goes. I am going to be painting my early 260 in the spring. I am painting it orange and absolutly love the color of you car. Would you be willing to tell me the name of this color. There are so many shades of orange it is hard to pick one unless you see it on a car
Thanks
Bob
My 240Z is actually not Orange. But depending on the light, I can see where you might make the mistake. Anyways, It's a Modified "Chrystler Industrial Red" used on engine blocks back in the 70's, I believe.
I took a paint sample (Dupli-Color, "DE 1632 Chrysler Industrial Red" Spray can sprayed on a piece of metal) to a paint shop in Everett, WA and told him I wanted "This color but brighter" He said "I can do that" So $100 later, I had a Half gallon of Brighter Orang'ish Red paint.
But when I paint the 260Z, it'll be Racing Orange from KustomShop. ( http://www.tcpglobal.com/kustomshop/kspsb8604.aspx )
Hope that helps,
Dave
Dave
Maybe I am color blind and deaf (like my wife seems to think) :) Thats the problem with looking at colors on the computor, every pic. looks different depending on the light. I checked out the color you are going to paint your 260. What a great color! It shows up as almost the same as your 240. I am going to the detroit auto rama at cobo hall in Feb. with any kuck they will have paint suppliers there that have actual samples of their colors Thanks for taking the time to respond to my question
Bob
