Posted January 12, 201015 yr comment_305796 My Z has a production date of 7/71. I just found a dashboard harness on Ebay that is out of a 10/70. Is this a match? Mine does have an automatic transmission and the auto seek am radio, but that shouldn't matter, right? I have 2 hrs to figure this out. Link to comment https://www.classiczcars.com/forums/topic/34375-dashboard-harness/ Share on other sites More sharing options...
January 12, 201015 yr comment_305798 RBULITSThere could be a slight difference. The automatic trans harness may have the circuit for the neutral safety switch which was incorporated so the car would not start in a gear other than PARK or maybe NEUTRAL.GOOD LUCK2MUCHZ Link to comment https://www.classiczcars.com/forums/topic/34375-dashboard-harness/#findComment-305798 Share on other sites More sharing options...
January 12, 201015 yr comment_305804 I've been through this before. (http://www.classiczcars.com/forums/showthread.php?t=19793) If the 7/71 harness is also for an automatic, there will be some differences, but you should be able to make it work. Will take some fiddling, and some connectors may be different.If the 7/71 harness is for a manual transmission, there will be several wires and circuits missing that your automatic car needs. Link to comment https://www.classiczcars.com/forums/topic/34375-dashboard-harness/#findComment-305804 Share on other sites More sharing options...
