A few years ago I came across the s30 design patents through a very rigorous (and crude) search through old nissan patents filed with the US. I remember saving the image on my old hard drive of a simple white and black "line art" Z. That hard drive is long gone, and I want to have those images again.
I tried searching through google patents and the closest thing I came across was this patent for a hood that looks like it might fit a Z:
Hood Patent
Does anyone know the patent number for the s30 design patent by nissan?
https://www.classiczcars.com/forums/topic/34384-original-s30-design-patents/
That is the add on that covered a hole in the hood for 74 models. the hole was a fix that dealers tried to solve the vapor lock issues with the 260's flat top carbs. Sorry I can't help with the original question, thought I would give info on what you found.
Dave
I'd did a google patent search and found patents covering the IRS design, side vent, steering, valve rocker arms, but noting covering the exterior design. :(
Can you post up the patent numbers for what you found? I'd like to see the ones for the side vents and rocker arms.
