I've used Mothers plastic polish with a buffball mini, if its a little oxidation it will clean it up. Also try a heat gun, just heat enough to soften but not distort the plastic sometime this will rejuvenate it .
Why is it always paint I have brought back panels to near new that were nearly white from aging back to black. And even harder to do take yellowed panels and make them white again. Like I stated before some polish and heat go a long way in the plastic world. You might ask why heat, heat softens the material allowing the pigments in the inside the plastic to come to the surface thus removing the faded area. It's a neat trick, try it before painting you might not paint any more.
