So I sat in my passenger side seat, pulled the lap belt across and now it does not retract. Anyone know how to fix this? It was working fine before. I did unbolt the contraption to hide some wires, and then I bolted it back in. Did I mess something up?
Thanks,
Wilson
https://www.classiczcars.com/forums/topic/34468-seatbelt-retractor/
Their is a plastic ring inside that usually brakes keeping it from retracting. I could not fix it in my 72, if it is broken in your car you will need a new belt. If you take it a part you will see what I mean.
I can agree about getting new belts, but the key is the strapping material I'm looking at replacing the material it may cost more but it will look original. I did this with my cars first harness it was always cheaper than buying new ever couple of years, for racing
