Posted January 20, 201015 yr comment_306784 I just bought a 1973 240Z and I'm trying to understand some of the wiring modifications made by the PO. I think I have them mostly figured out but this one baffles me. There is a red wire running from a plug near the passenger vent. To the ballast resistor (yellow wire goes to the electric fan). Anyone got any idea what it does? Link to comment https://www.classiczcars.com/forums/topic/34476-non-standard-wire-identification/ Share on other sites More sharing options...
January 20, 201015 yr comment_306796 I believe that the interior is for the accessory relay. I think maybe someone is tapping off 12VDC to go between the ballast resistor and the accessory relay. I'm guessing someone was looking for switched power, and if I was a betting man, I would suspect a bad accessory relay precipitated that hack. Link to comment https://www.classiczcars.com/forums/topic/34476-non-standard-wire-identification/#findComment-306796 Share on other sites More sharing options...
January 20, 201015 yr Author comment_306802 I believe that the interior is for the accessory relay. I think maybe someone is tapping off 12VDC to go between the ballast resistor and the accessory relay. I'm guessing someone was looking for switched power, and if I was a betting man, I would suspect a bad accessory relay precipitated that hack.Any idea what that relay does? The car is in a million little bits right now so I can't just unplug it and see what stops working. Link to comment https://www.classiczcars.com/forums/topic/34476-non-standard-wire-identification/#findComment-306802 Share on other sites More sharing options...
