Posted January 25, 201015 yr comment_307453 I'm in SoCal Ontario ..please call/text 909-224-4397 Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/ Share on other sites More sharing options...
January 26, 201015 yr comment_307502 I thought I'd seen an R180 4.11 in craigs list last week, (in Ontario) just in case you can use one. Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-307502 Share on other sites More sharing options...
January 26, 201015 yr comment_307523 Have you tried Zbarn? Give Roger a call-he may have one and can ship it to you. Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-307523 Share on other sites More sharing options...
January 26, 201015 yr comment_307527 New? or Used?Carl B. Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-307527 Share on other sites More sharing options...
January 26, 201015 yr comment_307529 Rich1:http://www.zbarn.com/70to78/used_steering.htm Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-307529 Share on other sites More sharing options...
February 5, 201015 yr Author comment_308653 never mind ..i got one from p n p from 1987 300ZX non turbo auto..but don't know if its 3.70 or 3.90..i know its only those gears for that car... Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-308653 Share on other sites More sharing options...
February 7, 201015 yr comment_308840 Most likely a 3.70. I just grabbed one from an 85 ZXT 5spd, and there was an 87 Auto with a 3.70 as well. I'm no expert on Z31s but this is what I saw. BTW, you can look on the data plate in the engine compartment to determine what the ratio is, assuming the diff or gears haven't been swapped... RC37 = 3.70, RC39 = 3.90, RC41 = 4.10, etc. Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-308840 Share on other sites More sharing options...
February 7, 201015 yr comment_308864 Does this mean that a 300zx's half shafts will mate up with 240 stub shafts, or do those need to be swapped out as well. I think I would rather have a 3.7 than a 3.9 (assuming I ever get hold of a decent 5 speed). Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-308864 Share on other sites More sharing options...
February 7, 201015 yr comment_308873 The Z31 uses a half-shaft with CV joints and an integrated diff side stub that mates with the R200 and is not compatible with the R180. The other end on the wheel side uses two different flanges and bolt patterns (turbo or non-turbo), neither of which are compatible with the S30 stub axle flanges. Replacement stub axle flanges for conversions are available from www.Modern-Motorsports.com.Conversion from R80 to R200 has been covered both here and over at Hybridz.org many times so I won't go into more detail, but rather recommend a search for existing content. Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-308873 Share on other sites More sharing options...
February 8, 201015 yr comment_308921 I'm in SoCal Ontario ..please call/text 909-224-4397I have a completely rebuilt one 3.70 (New bearing and seals) with anadized rear cover and new drain plug for $350 if you like. Also I have brand new one in the box as well. (3.56 and 3.90)PM sent Link to comment https://www.classiczcars.com/forums/topic/34547-im-looking-for-r200-370-or-39-diff/#findComment-308921 Share on other sites More sharing options...
