Posted February 4, 201015 yr comment_308491 Many threads on the Pertronix install and the option of going with the 1.5 OHM coil w/Resistor or the 3.0 OHM coil w/out the resistor. Tech support at Pertronix recommends the latter (Part 40511) - but this would provide full battery voltage in RUN to the Tach. Does anyone have this set-up and experienced any issues with the stock tach? Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/ Share on other sites More sharing options...
February 4, 201015 yr comment_308496 I am running the stock coil with the resistor and the tach works fine...... Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308496 Share on other sites More sharing options...
February 4, 201015 yr comment_308507 I've played with several coil selections with my Pertronix, both 1.5 and 3.0Ω coils with and w/o resistor. No tach issues in any config for me.FWIW, I've not been able to get any combination to run correctly with the Pertronix on my car except a 1.5Ω coil w/o resistor. Not what anyone recommends, I know. But using either a 1.5Ω w/resistor or a 3.0Ω Pertronix coil causes the engine to stop revving past a certain point, generally from 3500-4000 on up, depending on the combination in use. I am currently using the stock Nissan 1.5Ω. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308507 Share on other sites More sharing options...
February 4, 201015 yr comment_308538 Many threads on the Pertronix install and the option of going with the 1.5 OHM coil w/Resistor or the 3.0 OHM coil w/out the resistor. Tech support at Pertronix recommends the latter (Part 40511) - but this would provide full battery voltage in RUN to the Tach. Does anyone have this set-up and experienced any issues with the stock tach?This is also my consern Akorna before I purchase pertronix and bypass the ballast. I will be sure to follow this thread. thanks for bringing it up. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308538 Share on other sites More sharing options...
February 4, 201015 yr comment_308539 The crane electronic is really good no isues at all. Using an MSD usually your tach quits working. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308539 Share on other sites More sharing options...
February 4, 201015 yr comment_308544 I've played with several coil selections with my Pertronix, both 1.5 and 3.0Ω coils with and w/o resistor. No tach issues in any config for me.FWIW, I've not been able to get any combination to run correctly with the Pertronix on my car except a 1.5Ω coil w/o resistor. Not what anyone recommends, I know. But using either a 1.5Ω w/resistor or a 3.0Ω Pertronix coil causes the engine to stop revving past a certain point, generally from 3500-4000 on up, depending on the combination in use. I am currently using the stock Nissan 1.5Ω. Thanks for the info on the tach question Arne . Also, with your current set up 1.5 (stock coil) w/o resistor, have you ever burnt out a coil or have any other issues developed related to this set up? thanks John Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308544 Share on other sites More sharing options...
February 4, 201015 yr comment_308553 I use a mallory dual point dist with the pertronix ignitor and 1.5 ohm coil and stock ballast resistor with no problems. If your engine is not revving past a certain point it could be low voltage at the ignition run wire where the red wire from the pertronix goes. One thing I noticed with the pertronix upgrade for the stock dist is the trigger magnets are closer together than they are on the mallory setup, the mallory dist is much larger than stock so I thought there might be spark scattering under the cap at high rpm. I don't know just a thought. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308553 Share on other sites More sharing options...
February 5, 201015 yr comment_308555 Thanks for the info on the tach question Arne . Also, with your current set up 1.5 (stock coil) w/o resistor, have you ever burnt out a coil or have any other issues developed related to this set up? thanks John Not so far, but that is a concern. I've been running this way since last August. If your engine is not revving past a certain point it could be low voltage at the ignition run wire where the red wire from the pertronix goes.I've suspected something along this line, but haven't been able to pin anything down yet. Will do more testing at some point, as I'd really like to get the original coil off the car. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308555 Share on other sites More sharing options...
February 5, 201015 yr Author comment_308587 Thanks for the feedback - doesn't sound like anything conclusive at this point regarding the coil selection. I may experiment with this since I just installed a rebuilt distriutor due to a bad breaker plate - so I know that the shaft, vacuum and centrifugal advance is all working OK. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308587 Share on other sites More sharing options...
February 6, 201015 yr comment_308693 I upgraded my coil on my 240Z to a Crane Fireball performance one, and am using the Pertronix with the resistor bypassed. With the Pertronix you have to make sure to not leave the key on with the Pertronix plugged in. If you have to work on the car you have to unplug the Pertronix or it will overheat and burn up. Its a pain but the performance improvement from the Pertronix is worth it for me. I'm on my third Pertronix however. The first one was defective and the car would just shut down sometimes, and I couldn't restart it until I opened the cap to let the unit cool off. The second one I burned out because I left the key on without unplugging the Pertronix. The third one is working perfectly and I get good revs and power up to redline. When I go to my turbo engine I plan to Megasquirt and coil pack instead of the Pertronix.GregI'll add that the Crane performance coil I have is a 1.5 ohm coil. Edited February 7, 201015 yr by soundmasterg Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308693 Share on other sites More sharing options...
February 6, 201015 yr comment_308738 Thanks for the feedback - doesn't sound like anything conclusive at this point regarding the coil selection. I may experiment with this since I just installed a rebuilt distriutor due to a bad breaker plate - so I know that the shaft, vacuum and centrifugal advance is all working OK.Where did you purchase the reman dizzy and how much did you pay? Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308738 Share on other sites More sharing options...
February 6, 201015 yr comment_308757 I just bought an electronic dizzy off Craigs List for $60.00. I haven't installed it yet but I'm looking forward to the performance enhancement. Link to comment https://www.classiczcars.com/forums/topic/34647-pertronix-15-vs-30-ohm-coil-and-tach/#findComment-308757 Share on other sites More sharing options...
