February 12, 201015 yr Author comment_309519 test coil and test dizzy coming tomorrow morning sat 02-12-10. stay tuned for results. Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-309519 Share on other sites More sharing options...
February 20, 201015 yr Author comment_310120 picked up test coil, 1978 test dizzy, and compression tester. 1. problem unresolved with test coil (primary and secondary windings good).2. cleaning up dizzy a bit before testing on car (lube etc..) stay tuned.3. compression test next week, stay tuned. Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-310120 Share on other sites More sharing options...
February 20, 201015 yr Author comment_310121 gm hei contol module will be used with test dizzy, stay tuned. Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-310121 Share on other sites More sharing options...
February 22, 201015 yr Author comment_310326 tested test coil today with breaker point dizzy, no change ugh!completed compression check. 1 145, 2 140, 3 145, 4 145, 5 145, 6 145. all looks acceptable.tested test dizzy from a 1978 280z with gm hei. results in. no erratic bounce in timing at idle (great) when checked with timing light. cars runs better (I had to take it for a spin). all spark plug wires are firing at idle (verified with timing light) accept cylinder one. getting late atm so I will have to save the rest for latter but it looks good so far. have to replace the cap and rotor as they are very very old. mechanical advance working correctly. have to work out the kinks over the next couple of days so I dont want to say this one is solved just yet but it looks promising atm. Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-310326 Share on other sites More sharing options...
February 22, 201015 yr comment_310327 congrats, sounds good! Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-310327 Share on other sites More sharing options...
February 22, 201015 yr Author comment_310328 sent u and email adrian. check your box Link to comment https://www.classiczcars.com/forums/topic/34656-suspected-erractic-misfireweak-ignition/?&page=3#findComment-310328 Share on other sites More sharing options...
