Posted February 5, 201015 yr comment_308642 Hello all.I am trying to find the name of a specific piece i am missing. It is the part right under the glovebox. i can tell i'm missing something there because i see where the screws would theoretically go in should i have that completed panel.once again its the part that would go under the glovegbox but above the passenger legs (of course).Thanks Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/ Share on other sites More sharing options...
February 5, 201015 yr comment_308645 What year and model? Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308645 Share on other sites More sharing options...
February 5, 201015 yr comment_308654 Sounds like the "dog leg" trim. Those seem to break pretty easily. Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308654 Share on other sites More sharing options...
February 5, 201015 yr comment_308665 My 280Z had a bracket just under the glovebox, bolted to the door frame. You couldn't see it unless you crawled under, and it didn't seem to be doing anything. That dogleg part would cover it anyway. BTW, they call those kick panels on eBay, but it looks more like a water ski to me... Is there a picture of driver's side panel? Part of mine broke off and I'd like to fix it or make a new one. Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308665 Share on other sites More sharing options...
February 6, 201015 yr comment_308678 Hi , I found what is probably what you're looking for, in the 76 FSM. It's called the 'Instrument Panel Under Cover' as described on page BF-28. I realize this is out of the 76 280z FSM, but I'm pretty sure this applies to your year model because my 78 had this piece, where my 75 doesn't. I've attached the jpg for your use. Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308678 Share on other sites More sharing options...
February 6, 201015 yr comment_308682 My '77 & '78 had them on both side. Can't remember if my '76 did. I know my '74 260 did not. It really has no purpose other than the dress up the interior a bit, and hide any wires or the defroster tubes... sorta Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308682 Share on other sites More sharing options...
February 6, 201015 yr comment_308687 Here is a page in the microfiche files I found. It shows both sides on the 76 and later. Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308687 Share on other sites More sharing options...
February 7, 201015 yr Author comment_308811 Thanks guys. thats the part. instrument panel cover.sorry about the bonehead mistake of not listing my model and year...(two minutes too late)77 280zThanks once again. Link to comment https://www.classiczcars.com/forums/topic/34665-what-is-this-piece-called/#findComment-308811 Share on other sites More sharing options...
