Car won't start with key
anthony280z2+2
you said that it makes a noise by the link and not the relay by the foot well on the passenger side? The link is down by the starter, in fact it connects the starter to the wiring harness. If you are hearing noise in that location is sounds to me that you have a bad connection there. Check closely the small wire that connects to the solenoid spade connector.
This may sound like a funny question , but do the headlight work ok? and have you checked the fuses with a multimeter? Don't just rely how they look. Believe me I know. Especially the 3rd fuse up from the bottom on the driver side.
I hope this is not the case , but I have had two instances where a factory splice that is buried in the harness has failed. Check these things and if that doesn't fix the problem, send me a PM
Gary
Gary
Anthony, in the 1978 models, all the relays are inside that box the fusible links are mounted to. In previous years many of these relays were located inside the cabin.
I think the starter wire should run from the key switch to the solenoid, but it might run through a couple of connectors to get there. Do you have a factory service manual to help you with this job?
Someone posted a '78 wiring diagram not long ago. See if you can find it. If you can't, perhaps I can email it to you.
  • Who's Online   0 Members, 0 Anonymous, 648 Guests (See full list)
