Posted February 9, 201015 yr comment_309013 what year and month is my 240z. the vin no. is 18,144 and there's no holes in the steering wheel. thanks, timsz Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/ Share on other sites More sharing options...
February 9, 201015 yr comment_309015 My guess would be a mfg. date at the very end of 1970 or early 1971, likely sold as a 1971.If the data plate is still on the car, the date of mfg. should be noted there.Welcome to another Pennsylvania resident!! I'm just an hour or two down from you in Millersburg..... Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309015 Share on other sites More sharing options...
February 9, 201015 yr comment_309017 I looked up the Z Car Home Registry, and car hls3018124 was manufactured in 12/70, so I would guess that is the manuf. date of your car. This is Carl Beck's web sitewww.zhome.com. Look under zcar registers. Dan Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309017 Share on other sites More sharing options...
February 11, 201015 yr comment_309306 Have you looked at the info plate on the door jamb, or is the reason you're asking because that plate is missing? Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309306 Share on other sites More sharing options...
February 11, 201015 yr comment_309319 I have 18147 as an 01/70 build date....FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309319 Share on other sites More sharing options...
February 11, 201015 yr comment_309323 MVander 1971 HLS30-17821 L24- original 04-71A. Bjeres 1971 HLS30-18490 L24 #P30-19041 04-71these dates and HLS30 # are from the spread sheet attached.http://www.editgrid.com/user/mlwilliams/Z_Car_Registrythere are some strange HLS30 numbers on the sheet for that time period, could be a lot of mistakes. Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309323 Share on other sites More sharing options...
February 11, 201015 yr comment_309324 I have 18147 as an 01/70 build date....FWIW, Carl B. Carl , you mean 10/70 ? or 01/71 ? Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309324 Share on other sites More sharing options...
February 12, 201015 yr comment_309507 Carl , you mean 10/70 ? or 01/71 QUOTE]#18147 should be a 1/71 build. My records show the earliest 1/71 I have seen is #17475. The latest 1/71 I have seen is #20425. So I would estimate #18147 was built about the 2nd week of 1/71. There is a slim possibility that it could be a 12/70 car because I show #17925 as a 12/70, obviously later than the earliest, #17475. Carl addresses the reasons for this elsewhere, including ZHome.com. In any case it is nice to know of another surviving Series 1 Z. All Z Best,............................Kathy & Rick Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309507 Share on other sites More sharing options...
February 13, 201015 yr Author comment_309545 thanks for all your help. my door production date says 12/70. sold as a 71. thanks again. timsz. i had the same year car 35 years ago. i was young and so dumb and sold it. Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309545 Share on other sites More sharing options...
February 13, 201015 yr comment_309551 I noticed on the registry that a lot of build dates as late in the year as december were being counted as that model year, not the next year. If I have a build date of 9/77, and I've been told and thought for years that my car was a 78, is that accurate? How does that work? Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309551 Share on other sites More sharing options...
February 14, 201015 yr comment_309592 I noticed on the registry that a lot of build dates as late in the year as december were being counted as that model year, not the next year. If I have a build date of 9/77, and I've been told and thought for years that my car was a 78, is that accurate? How does that work?Being as your car is dated 09/77 it was probably shipped to the US and sold and titled as a 78 in late October or November, possibly later.Hope that helps. Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309592 Share on other sites More sharing options...
February 14, 201015 yr comment_309627 Carl , you mean 10/70 ? or 01/71 ? Oops.. yes - should be 01/71. thanks, Carl B. Link to comment https://www.classiczcars.com/forums/topic/34699-what-year-is-my-z/#findComment-309627 Share on other sites More sharing options...
