February 24, 201015 yr comment_310603 If you are happy with the current height, going with the KYBs and sticking with the stock springs is fine. If you decide to upgrade later to lowering springs, then the KYBs might not match up well. I believe they state that they should not be used with stiffer springs. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-310603 Share on other sites More sharing options...
February 25, 201015 yr Author comment_310628 Jeff G 78 said: If you are happy with the current height, going with the KYBs and sticking with the stock springs is fine. If you decide to upgrade later to lowering springs, then the KYBs might not match up well. I believe they state that they should not be used with stiffer springs.Thanks Jeff. I'll post what I decide...as well as the results. -dg Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-310628 Share on other sites More sharing options...
February 25, 201015 yr comment_310689 FYI... ride harshness has more to do with tire sidewall height, air pressure, and shock compression damping then spring rate. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-310689 Share on other sites More sharing options...
February 28, 201015 yr comment_310942 Check out techno toy tuning some great parts at good prices. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-310942 Share on other sites More sharing options...
March 1, 201015 yr Author comment_311106 I have determined that most of the front bushings will be replaced, along with most of the rear (a few were replaced already). The springs are good (as I had surmised) but all struts are blown. Additionally, the exhaust was not routed properly, and the differential bangs it on the down stroke:ermm:. These items will be fixed within the next week, so I'll report on the differences. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-311106 Share on other sites More sharing options...
March 1, 201015 yr comment_311113 Davey G said: I have determined that most of the front bushings will be replaced, along with most of the rear (a few were replaced already). The springs are good (as I had surmised) but all struts are blown. Additionally, the exhaust was not routed properly, and the differential bangs it on the down stroke:ermm:. These items will be fixed within the next week, so I'll report on the differences.Are you sure the Diff is hitting the exhaust on downshift? Usually a clunk in the rear is because of a worn differential mount. Zs are notorious for this. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-311113 Share on other sites More sharing options...
March 2, 201015 yr Author comment_311197 Z Tyler Z said: Are you sure the Diff is hitting the exhaust on downshift? Usually a clunk in the rear is because of a worn differential mount. Zs are notorious for this.Not on downshifting, but when going over bumps, etc. The pipe was not routed properly. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-311197 Share on other sites More sharing options...
March 2, 201015 yr comment_311236 Yeah, down stroke, the new cool term for down shifting. I like Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-311236 Share on other sites More sharing options...
March 11, 201015 yr Author comment_312128 The suspension components are ordered, and hopefully on their way. Also some weatherstripping. Fuel filter, seat foam, and new vinyl come next. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-312128 Share on other sites More sharing options...
March 11, 201015 yr comment_312152 Davey G said: The suspension components are ordered, and hopefully on their way. Also some weatherstripping. Fuel filter, seat foam, and new vinyl come next.If your are interested, you can come by and see what I have done with my '78. I am in the midst of re-assembly though. I live in Spring. PM me if you like. Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-312152 Share on other sites More sharing options...
March 12, 201015 yr Author comment_312254 ZCurves said: If your are interested, you can come by and see what I have done with my '78. I am in the midst of re-assembly though. I live in Spring. PM me if you like.ZCurvesI'd like that. I'll PM with some dates soon.Davey G Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-312254 Share on other sites More sharing options...
March 18, 201015 yr Author comment_312892 The parts for the suspension work came in today - new struts (KYB), bushings, tie-rod ends, strut mount insulators and bearings, sway bar end links, steering rack boots. When all together I'll see how the differential mount is doing. Rear control arms have new urethane.The car continues to run well, though a bit loud with only the rear muffler. It looks good on the exterior. Next it will get new weatherstripping (already in possession) and doors adjusted, and be taken on a day road trip! :classic: Then new foam & upholstery. I've already added new hood bumpers and levelers, new vent cowl grommets, new hatch door rubber bumpers and interior rivets. It's coming along! Link to comment https://www.classiczcars.com/forums/topic/34811-suspension-work-for-78-280z/?&page=2#findComment-312892 Share on other sites More sharing options...
