Posted February 22, 201015 yr comment_310330 I don't think most people here have seen my car. I didn't think it had any serious rust. I looked in all the usual places and everything looked pretty good. But I was thinking about selling my car so I was taking some more detailed pics of the dings. Like these cracks where the spoiler wing was molded to the quarter panel: When I saw the second pic I figured I better check that out. That whole molded in piece ended up coming off and I found this: Bummer... http://67.18.219.83/image_hosting/web_pages/Mike88se/images/240/240Z.htm Link to comment https://www.classiczcars.com/forums/topic/34832-oh-norust/ Share on other sites More sharing options...
February 22, 201015 yr comment_310357 That bondo is sneaky stuff:) Link to comment https://www.classiczcars.com/forums/topic/34832-oh-norust/#findComment-310357 Share on other sites More sharing options...
February 22, 201015 yr comment_310360 You may now have a case of "where do I stop".Good luck with it. Link to comment https://www.classiczcars.com/forums/topic/34832-oh-norust/#findComment-310360 Share on other sites More sharing options...
February 23, 201015 yr Author comment_310373 That bondo is sneaky stuff:) It is. I'm not crazy about the stuff. It has it's uses but this wasn't a good one. I was told all the bodykit parts were glassed in.You may now have a case of "where do I stop".Good luck with it. Thanks. I'm not the kind of person to strip the car down and dip it in zinc but I'll get whatever rust I see. I kept at it with a wirebrush on a drill going around the perimeter until I found where the rust stops. The rust only extended about an inch beyond the area you see in the pic. I guess water got in through those cracks and wreaked havoc. I can get rid of the rust. I don't know if I can mount the spoiler extension and make it look good. The extension is fine. Apparently it's made of fiberglass. Not a big deal all in all but it puts a damper on selling the car anytime soon. I'm not that enthusiastic about selling it anyway Link to comment https://www.classiczcars.com/forums/topic/34832-oh-norust/#findComment-310373 Share on other sites More sharing options...
