Posted February 23, 201015 yr comment_310380 i am installing my rt mount tommorrow..i was wondering if anyone has installed an rt mount in a 280z? i was wondering if i had to remove the driveshaft...instructions how to install would be great..:) ps ..using bump stop.. Link to comment https://www.classiczcars.com/forums/topic/34842-rt-mount-280zplease-help/ Share on other sites More sharing options...
February 23, 201015 yr comment_310400 I already PM's a responce but here it is again......When I installed The R/T into the 70' 240Z, the 74' 260Z and Z_Tyler_Z's 76' 280Z, all I did was drop the 4 bolts on the front diff crossmember, Loosen the 2 large nuts on the Mustache bar (so the diff could drop down more) remove the 4 bolts on the Strap and remove that, The slid the R/T into place.Took a little bumping here and there to get the bolt holes lined up and bolted it in. Then I installed a bump stop in the 240Z and the GM Poly Mount into the 260Z and Tylers 280Z.Takes a little finagling but you'll get it.Dave Link to comment https://www.classiczcars.com/forums/topic/34842-rt-mount-280zplease-help/#findComment-310400 Share on other sites More sharing options...
February 23, 201015 yr Author comment_310410 thanks a million... if i had a million i would still own a z. Link to comment https://www.classiczcars.com/forums/topic/34842-rt-mount-280zplease-help/#findComment-310410 Share on other sites More sharing options...
