i am installing my rt mount tommorrow..i was wondering if anyone has installed an rt mount in a 280z? i was wondering if i had to remove the driveshaft...instructions how to install would be great..:):)
ps ..using bump stop..
https://www.classiczcars.com/forums/topic/34842-rt-mount-280zplease-help/
I already PM's a responce but here it is again......
When I installed The R/T into the 70' 240Z, the 74' 260Z and Z_Tyler_Z's 76' 280Z, all I did was drop the 4 bolts on the front diff crossmember, Loosen the 2 large nuts on the Mustache bar (so the diff could drop down more) remove the 4 bolts on the Strap and remove that, The slid the R/T into place.
Took a little bumping here and there to get the bolt holes lined up and bolted it in. Then I installed a bump stop in the 240Z and the GM Poly Mount into the 260Z and Tylers 280Z.
Takes a little finagling but you'll get it.
Dave
