March 4, 201015 yr Author comment_311441 Adrian,1. I mistyped - sorry, it was measured 2.68 kOhm2. Re: options pin 1 kick-back - I will have to take the ECU's cover off to get my multimeter to the pin number 1 to get that voltage. I believe it does go to 400-600V range.3. Output stage transistor on the side - easy to replace since the solder points are big with plenty of space on the circuit board. There are actually two of them.4. I will trace pin 1 lead and see where it connects to on the board.I can borrow an oscilloscope from a friend of mine. I am not sure if my voltmeter has hFe setting. I will double check it.I'd love to fix my bad ECU even if I bought/have another unit. I don't mind working with electrical problems because there is logic to them (broken inside distributors or leaking oil pan is a different story).We can keep the resoldering ECU business off this board via private emails to keep other threads on top. If classiczcars members are interested, I can attach the PDFs/images of troubleshooting later to this thread to sum it all up.Thank you! Link to comment https://www.classiczcars.com/forums/topic/34858-76-no-start-problem/?&page=3#findComment-311441 Share on other sites More sharing options...
March 6, 201015 yr Author comment_311658 Hopefully, final update:- the replacement ECU got my car running again without any hot wiring gimmicks to the CSV.Thanks to all who helped me through this ordeal! Link to comment https://www.classiczcars.com/forums/topic/34858-76-no-start-problem/?&page=3#findComment-311658 Share on other sites More sharing options...
