Posted February 27, 201015 yr comment_310841 I have a 1976 280Z, it starts up cold just fine, runs great. But, after I turn it off for about 15 to 20 mins, it will run really rough and then smoth out after about 45 sec to a minute.Any advise? Link to comment https://www.classiczcars.com/forums/topic/34884-running-rough-after-restart/ Share on other sites More sharing options...
February 27, 201015 yr comment_310857 Thats an interesting problem, any more symptoms you can mention for us? FYI theres another club member who live in your town too if you didn't know. Edited February 27, 201015 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/34884-running-rough-after-restart/#findComment-310857 Share on other sites More sharing options...
February 27, 201015 yr comment_310878 Fuel is getting into the cylinders.Probable cause(s) in order:Leaking injectorsLeaking Cold start valveThermotime switch Link to comment https://www.classiczcars.com/forums/topic/34884-running-rough-after-restart/#findComment-310878 Share on other sites More sharing options...
February 28, 201015 yr comment_310933 Could be a little heat soak going on, nearly vapor locking , and after the pump brings fresh cooler fuel up, it goes away. Just a thought. Also, make sure you are not losing coolant. If you are leaking into a cylinder, it will run rough until you purge all the water out. Link to comment https://www.classiczcars.com/forums/topic/34884-running-rough-after-restart/#findComment-310933 Share on other sites More sharing options...
