Email logins are now active ×
Running rough after restart
cmbova
Could be a little heat soak going on, nearly vapor locking , and after the pump brings fresh cooler fuel up, it goes away. Just a thought. Also, make sure you are not losing coolant. If you are leaking into a cylinder, it will run rough until you purge all the water out.
  • Who's Online   2 Members, 0 Anonymous, 243 Guests (See full list)
