Hello, great site and will be here often. Had a few Zs earlier in life, back in it after 20 years.
Just bought a series 1 (9/70 prod #10112, E31 head,2400 valve cover,etc..). Been looking for an unmolested one for awhile and boy did I get it. But thinking beware what you ask for... no mods except a respray (slightly wrong red...ugh). Early CA blue plate, a little rust, I think(hope) not major. But EVERY rubber piece needs replacement (Bushings, w/s, are all falling apart). Most chrome/badges pitted or rusted. Engine not running but turns(hope not major, 2nd owner I bought from had for 30+ years said 77K shown is right, but could be 177). Not run for 16 years. Where to start...
So, hello, and I'll be here often!
Dave
Heh brother, sounds like you have a beauty! Wheres the pics :) ? Blue Plates are awesome on a Z. Had a Polar White 78 with some. What are your plans for the car, a complet tear down or just get her going?
Edited by WingZr0
Plan is mechanical first (I want to drive it dammit!). Then, depending on time&energy, could be a tear down for paint and all new rubber/glass/chrome.. Want to keep it original... I figure 5 year plan...
Some pics...not pretty (this is the first day anyway). Last one is worst of rust, both front fender wells just above & behind TC rod mount. How bad does it look? No other frame rust or in floors, rear is fine...funny it's just these two spots (just a few other bubbles on the usual outer panels).
Thx, Cheers!
Congratulations on the purchase. It looks like a great project car. Watch thous rust bubbles they are always larger than you see. Not to be the pessimist, but a rust spot like that usually means you will find more. That was a lot of steel that rusted threw, but maybe that spot the welds were not done right and that is why it rusted.
I would not worry to much about the color if your going to rebuild it more than likely you will be repainting it eventually.
These are tough engines I doubt it did much to the engine. Now you know why they were not driving it. Make sure you use a block dye on the head to check for cracks, beside you have a great reason to rebuild the engine from top to bottom.
