The factory R180 out of my z (it has a non-LSD R200 in it) is absolutely caked with grime. Is there a specific method and/or cleaner that's best for getting all that off? Can the whole assembly be dunked in a bucket full of solvent? Perhaps I could have it hot-tanked?
How about... wait for it... Gunk.
You can put the diff in a parts washer or a solvent tank, but if you submerge it you'll get solvent in the oil. Not sure what effect the solvent will have on the seals either if that matters. I put my bare housing in my solvent tank and cleaned it that way before reassembly, worked great.
  leftover z said:
Ya, there is more than one way to clean your rear-end...LOL
Actually, I was thinking that you have to be careful. If you scrub your rear end too hard with a wire brush, it might keep you from being able to drive your Z.;)
Ya, NOW you tell me...... :stupid: LOL
Soap and hot water, pressure washer works good. Light enough to bring to a car wash if you dont have these items! Easiest part on the car to clean, IMHO.
As others have stated, no solvent tank!
