Posted March 12, 201015 yr comment_312181 Ok guys I have a 74 260 and i'm looking for a set of rims. I have been looking all over the net. But all rims say they need spacers and stuff. Is there anywhere I can get a set of rims that just bolt on without spacers. Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/ Share on other sites More sharing options...
March 12, 201015 yr comment_312183 Yup. You need 4x114.3 (4x4.5). There are quite a few favorites, depending on your taste & budget. There are even some on eBay. Your tire store should be able to get what you want. If you see any member rides on here with wheels you like, just ask them what they are & where they got them. Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312183 Share on other sites More sharing options...
March 12, 201015 yr comment_312187 Z's run on 0 offset rims but you can use anywhere between +10 or -10. Any rims on like 1970's to 1980's rear wheel drive Celicas will work mostly along with 60 to 70's Mustangs or similar size muscle car like a Dodge Dart. Triumph cars too. Brands like Enki, Watanabe, American Racing, Ansen or anything old school. Look at Zbarn.com for a nice selection of old school bolt on and go wheels. Edited March 12, 201015 yr by WingZr0 Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312187 Share on other sites More sharing options...
March 12, 201015 yr comment_312203 u could also go and get some konig rewinds Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312203 Share on other sites More sharing options...
March 12, 201015 yr comment_312206 Ya get this my 09 Nissan Cube has same bolt patern as my 72 240 Z. Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312206 Share on other sites More sharing options...
March 12, 201015 yr comment_312207 c240z said: Ya get this my 09 Nissan Cube has same bolt patern as my 72 240 Z.But since those wheels have a front wheel drive type offset, that info is of no use to this thread....... Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312207 Share on other sites More sharing options...
March 12, 201015 yr comment_312215 WingZr0 said: ........60 to 70's Mustangs or similar size muscle car like a Dodge Dart.......Muscle cars had 5 bolt wheels. The versions of the vehicles you mention that would have 4 bolt wheels were the 6 cylinder versions and hardly what you'd call muscle cars...... Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312215 Share on other sites More sharing options...
March 13, 201015 yr comment_312289 sblake01 said: Muscle cars had 5 bolt wheels. The versions of the vehicles you mention that would have 4 bolt wheels were the 6 cylinder versions and hardly what you'd call muscle cars......Actually all of the Mustang II (74-78) and Fox Body Mustangs (79-93) had four bolt wheels. I think the were a different bolt circle diameter however. (4 1/4" comes to mind.)But then no one would ever accuse a Mustang II of being a muscle car. Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312289 Share on other sites More sharing options...
March 13, 201015 yr comment_312296 have you looked here?http://www.zparts.com/ads/wheels/wheels_fs.htmlI'm not knowledgeable on wheels, but I like the pictures here and make it easy to compare. (hope it helps, but have no info on how good the prices or the store... ) hopefully someone will chime in what the numbers mean. I've wanted to ask this before .... Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312296 Share on other sites More sharing options...
March 13, 201015 yr comment_312300 Walter Moore said: Actually all of the Mustang II (74-78) and Fox Body Mustangs (79-93) had four bolt wheels. I think the were a different bolt circle diameter however. (4 1/4" comes to mind.)But then no one would ever accuse a Mustang II of being a muscle car.I really don't consider anything built after about 72-73 to be a muscle car. There were preformance cars built after that but that's about where the true muscle car era ended IMO. Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312300 Share on other sites More sharing options...
March 13, 201015 yr comment_312338 sblake01 said: but since those wheels have a front wheel drive type offset, that info is of no use to this thread....... wow Link to comment https://www.classiczcars.com/forums/topic/35020-260z-rims/#findComment-312338 Share on other sites More sharing options...
