Posted March 14, 201015 yr comment_312389 I have a late '73 (7/73 I believe) with an L28 and an electric fuel pump. The power for the pump, which is located in the engine bay, comes off the ignition coil feed. I would like to reroute this so that there is no parasitic drain off the distributor current, and I'd also like to put in a cutoff for safety and theft purposes. Does anyone have a suggestion where I should intercept the harness so that can put kill switch in the cab, and still have it switched to the ignition?Thanks. Link to comment https://www.classiczcars.com/forums/topic/35037-electric-fuel-pump-question/ Share on other sites More sharing options...
