Posted March 15, 201015 yr comment_312505 Does anyone know the correct bolt size for the splash pans?Thanks,Mark Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/ Share on other sites More sharing options...
March 15, 201015 yr comment_312513 97.23% chance they are M6 x 1.00. 15 mm length would be just fine. Not positive since I'm not in a spot where I can check, but the only other size that even remotely possible is M5 x 0.8. Can't imagine they are M8x1.25, but I've never had a Z in the shop that had a pan or had a chance to put one back on! The holes I've seen in the rad support and frame rails seem to me to be M6 Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312513 Share on other sites More sharing options...
March 15, 201015 yr Author comment_312524 Thanks. Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312524 Share on other sites More sharing options...
March 15, 201015 yr comment_312528 They are on ebay all the time - I've been looking for a splash pan with no luck but I see the bolts - you have the pan and can't find the bolts - life is a strange thing some times! Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312528 Share on other sites More sharing options...
March 15, 201015 yr Author comment_312540 Yea e-bay, $13.99 + 3.95 shipping for 10 bolts. I'm 92.23% sure the .20 ones from my the hardware store on the way home will do just fine....Good luck finding your pan. I just got mine....they are getting expensive. Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312540 Share on other sites More sharing options...
March 15, 201015 yr comment_312550 agree with zKars...6mm x 1.0 x 15mm...just happen to have them sitting right here on the desk... webdawg1 Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312550 Share on other sites More sharing options...
March 15, 201015 yr comment_312551 I got a deal on a late model pan,can I adapt it to my '71? Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312551 Share on other sites More sharing options...
March 16, 201015 yr comment_312598 My problem is not the splash pan, it is on the garage wall nice and straight, rust free and in primer. Nor is it the bolts, I have the genuine Nissan number on file and ready to order. My problem is I have to remove 9 broken off bolts. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312598 Share on other sites More sharing options...
March 16, 201015 yr comment_312602 Lonny-I hate it when that happens - once is bad enough, but 9 times! Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-312602 Share on other sites More sharing options...
December 22, 201014 yr comment_339566 Sorry to bring up an old thred, but I can't find in my parts catalog the part number for the 240Z pan screws/blots. does someone have it? Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-339566 Share on other sites More sharing options...
December 23, 201014 yr comment_339581 ajmcforester said: Sorry to bring up an old thred, but I can't find in my parts catalog the part number for the 240Z pan screws/blots. does someone have it?08360-51226http://www.classiczcars.com/forums/showpost.php?p=272033&postcount=5-Mike Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-339581 Share on other sites More sharing options...
December 23, 201014 yr comment_339583 Thanks Mike, I was touring the US in conferences when that post was made Link to comment https://www.classiczcars.com/forums/topic/35053-spash-pan-bolt-size/#findComment-339583 Share on other sites More sharing options...
