Spash Pan bolt size?
Mark Schue
97.23% chance they are M6 x 1.00. 15 mm length would be just fine. Not positive since I'm not in a spot where I can check, but the only other size that even remotely possible is M5 x 0.8. Can't imagine they are M8x1.25, but I've never had a Z in the shop that had a pan or had a chance to put one back on! The holes I've seen in the rad support and frame rails seem to me to be M6
My problem is not the splash pan, it is on the garage wall nice and straight, rust free and in primer. Nor is it the bolts, I have the genuine Nissan number on file and ready to order. My problem is I have to remove 9 broken off bolts. :angry:
Bonzi Lon
  • 9 months later...
