Posted March 17, 201015 yr comment_312760 For those of you who are interested, I found a place in New York that does Plastic Rechroming. Not the Spray Metalization crap either, but the real deal. You can find them on the web at www.4chrome.com. They charge approximately $5/sq inch. which sounds hefty, but with little alternative....what cha going to do?? After spending $$$ on my Z, I just couldn't do the Chrome Paint or Spray Metalization - So I just do a little at a time...which isnt so bad. Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/ Share on other sites More sharing options...
March 17, 201015 yr comment_312762 What's wrong with spray metalization? The results I've seen up close and personal with Spectrachrome in particular look as good as vacuum bagged chrome plastic. Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-312762 Share on other sites More sharing options...
March 17, 201015 yr comment_312772 For re-chroming the tail light trim I don't think it would be to expensive. Considering they aren't made anymore, I may look into it.carl Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-312772 Share on other sites More sharing options...
March 17, 201015 yr Author comment_312801 What's wrong with spray metalization? The results I've seen up close and personal with Spectrachrome in particular look as good as vacuum bagged chrome plastic.While looking for a place for Re-Chroming, I was told by several places that if the object being chromed was to be "Outside", that it would have to be sealed and then would have a shorter life expectancy than the traditional method......That is why I chose 4Chrome.com. Perhaps "Crap" was too strong of an adjective. Ultimately if you or anyone else is happy with the results of Spray Metalization, thats fine! Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-312801 Share on other sites More sharing options...
March 17, 201015 yr comment_312803 While looking for a place for Re-Chroming, I was told by several places that if the object being chromed was to be "Outside", that it would have to be sealed and then would have a shorter life expectancy than the traditional method......That is why I chose 4Chrome.com. Perhaps "Crap" was too strong of an adjective. Ultimately if you or anyone else is happy with the results of Spray Metalization, thats fine!I was making a serious inquiry, what's WRONG with etc... as I am considering doing some chrome trim strips with this product (Spectrachrome). I have to do the prep myself which is not too fun.I was told about the durability or lack thereof and the shop I am considering shoots the final product with clear coat and they said that does the trick.Have you actually used the 4chrome.com shop to rechrome your trim strips? Did they do a good job? Edited March 19, 201015 yr by dhp123166 Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-312803 Share on other sites More sharing options...
March 19, 201015 yr comment_312980 I sent a picture and blurb to 4chrome.com the day before yesterday and have not heard anything back yet.Maybe they're being flooded with requests? Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-312980 Share on other sites More sharing options...
March 20, 201015 yr comment_313099 I used these guys based out of Washington State to re-plate the chrome on my 240z tail light trims. The result was impressive.http://www.cvvacuumplaters.com/restoration.htm Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-313099 Share on other sites More sharing options...
March 20, 201015 yr comment_313133 You might also contact the company noted below. They did a nice job on my 260Z tail light trims at a cost of $260.00 in October 2007. They may have rechromed 240Z tail light trims in stock. Custom Coatings 4794-C Woodlane Circle Tallahassee, Fl. 32303 http://www.customcoatings.net/ Regards, Fixitman Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-313133 Share on other sites More sharing options...
March 22, 201015 yr Author comment_313301 I was making a serious inquiry, what's WRONG with etc... as I am considering doing some chrome trim strips with this product (Spectrachrome). I have to do the prep myself which is not too fun.I was told about the durability or lack thereof and the shop I am considering shoots the final product with clear coat and they said that does the trick.Have you actually used the 4chrome.com shop to rechrome your trim strips? Did they do a good job?No problem, I am getting a quote from them at the moment. I want to get the taillight bezels and the interior door pull bezel rechromed so I'll post my findings...Perhaps everyone should start posting the quotes. It would be good comparison shopping for all of us. Edited March 22, 201015 yr by ZCurves Link to comment https://www.classiczcars.com/forums/topic/35084-re-chroming-plastic/#findComment-313301 Share on other sites More sharing options...
