BTF/PTM Posted March 20, 2010 Share #1 Posted March 20, 2010 So I filled the tank full for the first time after discovering the level sender has a problem when the car ran outta fuel while still reading nearly full. Previous owner had the tank hot tanked n new lines fitted including the filler neck, but the sender seal is original. It leaks badly, it's a steady stream of fuel that I traced with a flashlight to that seal. It looks like I can replace this seal with the tank still in the car if I pull the right rear wheel - is this a fair assessment, or should I gear up for dropping the tank? Also, is this seal still available, or should I plan on making a gasket? Link to comment Share on other sites More sharing options...
Zs-ondabrain Posted March 20, 2010 Share #2 Posted March 20, 2010 It's just a rubber O-Ring, I thing MSA has them as well as new senders if your need.Easy fix. Unplug the wires, pound the seal ring counter-clockwise? remove the sender and old seal, replace the seal, reverse the operation. Done.Dave Link to comment Share on other sites More sharing options...
webdawg1 Posted March 20, 2010 Share #3 Posted March 20, 2010 Should be able to order you a couple from your local Nissan dealer...or other part source of your choice...Part number: 17342-18000webdawg1 Link to comment Share on other sites More sharing options...
BTF/PTM Posted March 20, 2010 Author Share #4 Posted March 20, 2010 Thanks!! I ordered a pair of gaskets through Mossy Nissan, should have them mid-week. Ordered a battery hold-down, too, since the car is currently using a come-along strap.Is the car safe to drive if I keep maybe a quarter tank in it so that the fuel doesn't reach that leak? Dealership advised me of the worst-case scenario where a bad backfire could ignite fuel vapors around the tank :paranoid: Link to comment Share on other sites More sharing options...
zKars Posted March 20, 2010 Share #5 Posted March 20, 2010 Fuel leaks are never safe. Keep the car outside and not driven if you can until this is resolved. Jim Link to comment Share on other sites More sharing options...
BTF/PTM Posted March 20, 2010 Author Share #6 Posted March 20, 2010 Agreed, I didn't really need to ask the question to know the safe answer. I'll be tinkering on and off with other parts of the car throughout the weekend, so the garage will stay well ventilated.Fuel leaks are never safe. Keep the car outside and not driven if you can until this is resolved. Jim Link to comment Share on other sites More sharing options...
BTF/PTM Posted March 25, 2010 Author Share #7 Posted March 25, 2010 An update, I got the new seal installed, it was as easy as previously mentioned. I used a hammer and a drum stick to R & R the securing ring. The old seal was likely the factory part, I don't think it could even be called rubber anymore. It took longer to get the car on jack stands than it did to replace the seal. If only all repairs were that straight forward. Link to comment Share on other sites More sharing options...
