November 8, 201113 yr comment_371257 madkaw said: Put your numbers in Mike and they come up under courtesy as stoppers at 10$ each - ouch! Didn't say upper or lower, but I assume they are the same and I will 4'of themUpper and lower are different. Upper has a larger hole as the mounting bolt tapers inside the mustache bushing. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371257 Share on other sites More sharing options...
November 8, 201113 yr comment_371258 Thanks for the heads up on the washers. Just called Nissan and straightened things out. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371258 Share on other sites More sharing options...
November 13, 201113 yr comment_371694 Cross posting, just finishing my redo of my bushings. Worked out great... Mustache Bar bushing flare tool Tool top, socket on the bottom Looks good! Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371694 Share on other sites More sharing options...
November 13, 201113 yr comment_371706 Looks a 1000 times better-great job. Now help get that tool Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371706 Share on other sites More sharing options...
November 13, 201113 yr comment_371713 Kevin LeBlanc at the Austin Z-Clinic had this tool made up. We're kicking around the idea of making up a batch of them. It would have been nice to have two of them, one for each side as the socket side which was already flared ends up not as clean as the flared side we did, but still a huge improvement over my hack saw job above...Control arm pin pullers and this little flare tool are almost required for stock Z rear end work. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371713 Share on other sites More sharing options...
November 14, 201113 yr comment_371747 Sorry..but where can you get OEM bushings for the whole car? Dont want them urethane.. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371747 Share on other sites More sharing options...
November 14, 201113 yr comment_371753 Reread this thread and the other thread going on right now on the site about the part numbers-they're all there. Order from your local Nissan dealer and pick them up or I have had good results with Courtesy Nissan. They stock a lot of older parts and will ship to your door. You'll need the bushings and two different washers-three separate part #'s Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371753 Share on other sites More sharing options...
November 14, 201113 yr comment_371764 Koalia said: Sorry..but where can you get OEM bushings for the whole car? Dont want them urethane..Like Steve says, get the microfilm and order the parts (local dealer, zcar.com, courtesyparts.com, FactoryNissanParts.com, etc...) My car only has urethane on the transmission bushings, inner rear control arms and sway bars. You'll need to swap out the 240Z part number for the 280Z lower differential stopper bushing. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-371764 Share on other sites More sharing options...
November 29, 201113 yr comment_373248 any way I could borrow your bush flaring tool, I live in north texas and would be more than happy to pay shipping both ways..thanks john bell Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-373248 Share on other sites More sharing options...
January 10, 201213 yr comment_377087 Quick question for those who have installed OEM bushings; does it matter if you install the bushing and flare at the top or bottom of the bar? I'm guessing not, but I would like this to be as original. Thanks. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-377087 Share on other sites More sharing options...
June 7, 201312 yr comment_425067 GreenZZZDid Kevin ever have a batch of flaring tools made up. I would like to get one for my specialty Z tool set. I am getting ready to replace these bushings soonThanks, Charles Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-425067 Share on other sites More sharing options...
June 7, 201312 yr comment_425091 ollie said: Quick question for those who have installed OEM bushings; does it matter if you install the bushing and flare at the top or bottom of the bar? I'm guessing not, but I would like this to be as original. Thanks.Don't think it matters. I put the tool'd flare on the top thinking it would be rougher than the factory produced flare. The thinking was the weight sits on the bottom flare and you want that to be smooth. Ends up my top flare is smoother than the bottom since the socket put a bit of mar on the bottom lip, but otherwise its real good. Link to comment https://www.classiczcars.com/forums/topic/35145-oem-bushings-for-moustache-bar/?&page=2#findComment-425091 Share on other sites More sharing options...
